Nice thread, just as I was going to revive an old ECU thread someone started a new one. Things have changed since the last one so new discussion is good.
Narrowed down the selection to Electromotive, Motec, Autronic, Haltec, Accel DFI, and EFI Technology.
After pricing it was further narrowed to Electromotive, Autronic, Haltec, and Accel DFI which are all in a similar price range. The Motec and EFI tech. being roughly double that price range.
Further discussion with the longtime experts at Kinsler Fuel Injection suggests that the Accel DFI has the most bang for the buck. With Electromotive and Haltec generally having more compatibility/dependability issues than the Accel. The Autronic was eliminated because it doesn't operate in closed loop.
Looking at the free download software the Accel also looks the most advanced as far as it's utilization of the latest windows software. The only thing that bothers me is it only has one ignition output so if you want distributorless ignition it takes another $300 ignition box.
The nicest feature seems to be the ease of setting the initial map to get the thing started. You enter all your engine parameters like displacement, compression ratio, injector size, fuel pressure etc. From forum posts it looks like this gets you started right away. It also has a volumetric efficiency predictor which has settings for the mechanical aspects of the intake and exhaust system like valve size/timing and port dimensions.
The average price is $1650 for a kit with ECU, sensors, flying lead wire harness and narrow band O2. The UEGO linear O2 sensor option is another $950. With the wideband O2 you can precision tune at all rpm/throttle ranges, as opposed to narrow band which only works at part throttle.
According to Kinsler the wideband O2 will correct an imprecise map but the key to maximum performance is a map that's correct in the first place. You get the map close and then datalog the corrections that the O2 makes and set your map to that. Ideal performance happens when the mixture is optimum for every single combustion stroke, and not when you miss a couple of beats because your waiting for the sensor to correct.
It connects with a serial port to a laptop (rec. minimum 350 PII, 64 meg ram) but can adapt the serial cable to USB.
The real clincher for me is the closest distributor is Accel DFI and the guy has a chassis dyno.
Haltech
EFI Technology
Motec
Electromotive
Autronic
Accel DFI
KINSLER FUEL INJECTION
Kinsler has a really nice catalog which also has a lot of info on fuel systems and a comparison chart of some popular programable ECU's.
