Hi all - me again
Just spent a day over at a fellow enthusiasts place having a check over his Ultima Can-am - Very nice... M48Pro - 6.3L Chevy - Kinsler TBs - Dart heads = 600+BHP Hmmmmm
Now, getting back to above remarks - Lynn - I was impressed with what the guys on the DIY site are up to - mainly because I like their dedication to working out 'how it all works' + I like electronics - especially DIY electronics. I am not saying that I would prefer their ECU to Motec - but I do like the idea of 'playing about' with an ECU that is being 'group advanced' by a number of die hard petrol heads.
I am not sure why people have too many problems getting going with Motec either. I purchased an ECU from Frazier - read the user manual (twice, or probably more!) looked at the wiring schematics, then decided how to install it. I wired all the loom connections to terminal strips to allow easy probing at a later date for diagnosis of any problems we may encounter + wired all the engine connections, i.e. injectors, sensors etc etc through two circular military type multipole bulkhead connectors. This then leaves an 'umbillical cord' type loom connection from engine to bulkhead so that if we need to pull the engine out, two-half-twists and the only connections left are alternator and starter, making a much quicker installation.
We modified a distributor, cutting the top off and adding a hall effect pick up for sync pulses as engine runs sequential injection + individual coils. Loaded a Motec supplied 'base-map', primed, pressed the start button and away she went - first time, no problems. Roy nearly fell over with the surprise of it actually working, especially so easily. Sure that was only the starting point, we then had to get timing correct, main map, accel enrichments, cold start + warm up etc - but it all fell good - bit by bit.
Now, from cold, ignition on, depress loud pedal fully twice, (which momentarily batch fires all injectors once 89% throttle is reached) to wet the manifold. Remove foot from loud pedal and press starter button. Engine fires from cold normally within 1-2 secs and idles just fine.
From hot - ignition on - press start button - its that easy!
I love injection systems!! now where can we fit a couple of Garrett T035s??? /ubbthreads/images/graemlins/grin.gif
Another plus point for (any) EFI system is if you are lucky to have several vehicles, you would only be able to drive one at a time so the ECU could in fact be shared, and programmed / installed prior to using vehicle. As they only take a couple of mins to reprogram, its not as daft as it sounds.
