It will be fitted to a 1966 289 engine for a Mk I replica, its the adaptor for remote engine oil cooling allowing two pipes for the cooler and fitting the filter.
thanks guys, I'm following up those leads.... what I should have also said is that I want an adaptor exactly the same as the one shown, as per ogiginal 289 engines.
Im still searching and will let you know if I have any luck.
