Re: Oil pressure surging
Hello Howard & Mark,
The Balancing Machine is a "Sunnen DCB 750". I believe there are bigger and later model's in the industry now but this was the model mentioned to me. At the same time I should point out that there may be other makes out there that do an equally good job. The shop here in NZ ( ERS ChCh.NZ)that has one wont be of any use to you guy's (Unless you come down to our SFOS series and need to rebuild your motor's to keep up with Russ Noble), but with balancing the guy operating the machine and weighing the pistons and rod's to work out the bob-weight's is real important to the quality of the job. With mirror balancing you place the two flywheels on a mandrel, both flywheels must have their crankshaft flange side's to the same end of the mandrel. With reference to the staggered bolt pattern of the flywheel attachment bolts each flywheel must be 1/2 turn (180deg) from the other, now the two f/wheels & mandrel are placed on the balancer and checked. Material is removed/added to the unbalanced F/wheel to achieve a balanced state of the whole assy. (One Flywheel that you know has been correctly balanced for the motor in question, the other being the Flywheel that needs to be balanced), this can be done on a machine that spins up the whole assy or on a couple of knife edges.
Now this is where the Sunnen machine apparently shines, it operates at very low rpm and is very sensitive. With the above scenario we have two Fly wheels which on their own have an out of balance factor of either 50 or 28 oz.(You guy's with neutral balance can open another *fosters,bud,speights about now*). After you have balanced to a neutral state for the assy the two flywheels cancel one another out,BUT the out of balance individual flywheels are at different points along the mandrel, when spun at high rpm they try to whip the mandrel shaft which confuses the balancer. This has been a major factor with stroker crank's and longer heavier rod and piston combinations where with the old style high rpm balancers the crank would actually deflect/bend during the balancing process.Obviously if this was not detected at the time, when installed in the motor the crank tries to achieve its "bent balanced" state at high rpm much to the distress of the brg,s etc. With all the friction now being created a lot of power is lost for no good reason.
As you can probably gather Im not a big fan on "mirror" balancing for the above reasons, but given a good machine and operator it should be fine for Howards application/rpm range.
Howard I am not trying to ruin your day, and given an endless money jar we would all do things different. If your at all concerned after reading this pull the rear main cap while the pan is off, if there is no sign of movement on the cap/block mating faces its probably OK. Sorry to be so long winded about this but I realise some of you will have trouble understanding the process. Hopefully it's slightly clearer than mud!!
Regards Jack.
