original style water pump
Doc Watson
Im in the process of getting the bottom end of my 1966 block sorted out for my car. Its a mustang block 30 thou overbore 289 and im using the original crank and heads (exhaust valve seats and phospher bronze guides have been fitted). I want to make the engine as 'period' as possible externally, correct inlet manifold, 48 IDA's and correct bellhousing (for my ZF-2 trans), and correct pan.
The question is.... what was the original water pump used in the 289 engine? I have a supplier who can give me the correct pullys and bracket for the alternator but I cant find any reference to what water pump to use. Ideally I would like a high volume pump but with the same external dimensions as space is tight around that area of the car. BTW no air con in this car......
Anybody out there know?
Doc Watson
