Pictures and Measurements Help.
Can someone measure the bolt circle on the Audi transmission? I need to know if I can fit it on the same adapter plate that I have for a 901 Porsche box.
I also need some one to take a picture of the output shaft flange. I am wondering if I can plug the 901 output shaft flanges into the Audi differential. This would save some time.
The bolt circle for the 6 bolts that hold the CV joint to the drive flange is 3.685 inches. They are 10m/m bolts. This is larger than the 901 drive flange. I don't know about the dimensions of the stub axle that goes into the transaxle but I would suspect that they won't interchange.
