RichardH
AKA The Mad Hat Man
Many years ago, when I was working in the aircraft industry there was a fluid called Alacrom???? Which was, I believe a Chromate primer for Aluminium articles which needed to be "fettled" to fit. At the same time I used to use a yellow paste when fitting steel bolts thro Alloy panels. I believe that this was to reduce/stop electrolytic corrosion.
Having spent 9 hours!!! yesterday
removing a siezed bolt from within an Aluminium Alloy casting (Water pump/Timing cover on a Landrover) because of corrosion, sufficient to shear the bolt twice!! (once with an external stud remover), thought I would look into trying to obtain something to ....
a) Seal against Oxidisation of the machined Alloy housing.
b) Protect against the new bolts corroding into the housing again.
I know that some peeps swear by using loads of Coppaslip or similar but do any of you know where I can get small quantities of Alacrom (or similar) and this yellow anti sieze/corrosion inhibitor paste from?
Preferable (as usual) without spending a mortgage on getting it
