I have got to the stage of fitting up the rear of the 5000 and have run into bother, my setup consists of,
DRB uprites with C4 Corvette hubs and stock vented rotors, and 15" Weld racing wheels, and I tried to fit a pair of Outlaw 2500 series 4 pot calipers.
problem is two fold , the Outlaw caliper is to wide and rubs on the wheel face and also slightly to big in dia, even when I set it up with a couple of thou clearance to the rotor it still rubs on the rim,
the Weld wheels do have a slight taper on the rim well which compounds the problem even more, as the only way I can get things to work is to run lots of spacer. which one I don't like and two, it makes my over all width a bit excesive.
So my question to the masses is. has anybody had a similar clearance problem with the Vette brakes and 15 "wheels and how did they solve it.
appreciate any help I can get.
cheers John
cheers John
