I built a serpentine belt setup for my 331 to drive waterpump and accessories.
THis is how it looks like. The red line shows how the belt will run. It fits great. Even with my most forward engine position it still clears the firewall by 1/2". The short reverse waterpump helped to achieve this.
I fabricated idle pulleys out of 7075 because i couldn´t find what i needed. The idle pulley on the alternator side is a fixed mounted one.
The one above the AC compressor is mounted on a modified ford automatic tensioning unit.
The part no of this unit is F 87 E 6B209 BB.
In order to find the correct length i need to know the correct pretension adjustment of this automatic tensioner. the red arrow in the top picture above you show the direction of tensioning.
on the tensioner it self there are 4 marks on the housing and one arrow on the movable part.
my question is now how to set it up correctly. the picture shows the position without any tension on it. My assumption is that the middle one of the 3 left hand side housing marks shows the correct tension, the one to the left of it the max tension position and the one to the right of it the minimum tension position.
Is this correct?
Ford specialists please help, couldn´t find any information on the net.
TOM
Is this correct?
TOM
