Good day,
Well, winter boredom has set in. (-10F this morning)
Could an owner of a SUPERFORMANCE MKII measure the outside diameter of the round bar spanning between the two front quick-lifts. And if possible, post a photo of how the front quick-lifts are attached to the chassis. I seem to recall they are welded on, but I could be mistaken. (Would be great if they bolted on and were removable as a unit)
I'm starting to work on a few small projects until my GT is completed and delivered. (Front & rear tow-hooks right now)
I'm also looking for any suggestions and details for other things I can fabricate until my car arrives in frozen Chicagoland. Such as: The rear clam tilt limiting cable. Brackets for rear clam support struts. Rear lic. plate holder, etc....
All will be added to a new section going into in my SPF GT Owners Manuals for others to build in the future. (Great suggestion from an owner) (You'll get your name added a a contributor too if you like) You can post here or to me directly.
Thanks,
Blas
Could also use the bolt circle diameter for the steering wheel center. Thought I saw a drawing somewhere?
Thanks,
Blas
