Southern GT parking brake bracket MC4
Morten
Mortified GT
Hi David,
Brackets like these?
They’re stacked on Mick’s shelf, but not for long as all stock will be packed up and moved to the new owner’s workshop. Its also some shims you might need
Give Mick a shout before its too late to get the parts.
Davidmgbv8
Thanks Morten, I have a couple of bits I am awaiting to be sent so I will see if Mick can add this. Of more importance, Friday night I tried to figure a way to to orient the arm assembly to allow a straight pull of the hand brake lever vs reverse. Do you or any other SGT builder have a photo of the MC4 parking brake and the cable/ actuator arm in place.
Morten
Mortified GT
I’ve seen some swap from trailing to leading caliper mounts which gives a straighter handbrake run. But if the handbrake cable is long enough then, thats another question.
I have Brembo handbrake calipers. Solution was to cross the cables under the engine Left to rightside, Right to Leftside onto the bar for a nice direct pull. I also made the bar longer.
morten
