Thanks Jack, Just finished pulling the pan & main cap & checking that 1/2 hour ago - all looks good on this end.
I was confused about how it could have worked at all until I pulled the bearing and looked inside - Apparently when the shaft was simply rubbing on the bearing (aluminum casing) it was able to slide over the surface and was easily enough overcome with the shift forces. However, after enough aluminium "bits" and particles got in there, it completely seized up against the shaft and that's when everything went haywire.
As to the crank & bearings - measured fine - no signs of wear - I got REALLY lucky!
Thanks again!
Dave
Thanks again!
Dave
