Well, the G50 crown wheel is on the "wrong" side anyway ('box in upright position) so that would be very advantageous for me.If you use two spur gears ala Quick Change your rotations will change from there onward,.
Not for me but has anybody done that to a manual gearbox? Is there a thread or a link about it?other way would be internal gear similar to cresent type pump gears out of auto trans to maintain correct rotation..
You mean transverse gearbox?My thoughts..M.I.S.S. make it simple ******
Some of the brabham F1/indy trans by Weismann split the final drive reduction by a combo of spiral bevel on the input ( small size-less torque requirement @ that point & to convert from the engine crankshaft thru 90°) to allow for spur gears for all trans ratios & further reduction to final drive/output shafts ( these were accessable by pulling side cover to make rapid ratio changes possible ) and also allowed some design freedom to get axle/output shaft heights at correct levels.
Yes, but with inline motor, input shaft for trans is pinion of a lighter ring/pinion which converts it to traverse shafts from thereon...Well, the G50 crown wheel is on the "wrong" side anyway ('box in upright position) so that would be very advantageous for me.
Not for long, cos then you will be driving on the coast side & coasting on the drive side of the CWP- it probably wont like that long term![]()
Not that I can think of offhand, just used it as a possibility
Damn! You are right. I've just double checked the pictures of the Cooper Climax gearboxes - the Mk2, which was fitted with a drop gear, used a custom CWP (straight bevel instead of spiral bevel) so that's why. The Mk1 did not have a drop gear and the CWP was standard (spiral bevel).Not for long, cos then you will be driving on the coast side & coasting on the drive side of the CWP- it probably wont like that long term![]()
^ Yes, that's what I was talking about.
BTW why did Cooper decide to make a straight bevel CWP rather than a spiral bevel but of oppposite hand?
^ So, if it was a G50 gearbox, would an opposite handed (or mirror imaged) hypoid bevel CWP work?
Sorry for late response. Anyway, if I flip the trans, the output shafts would be about 5" too high. Actually I don't need drop gears either - just trying to figure out how to use the G50 that's all. In upright position my output shafts are only about 1.5" too low, so if I use, say, a 2" drop gear, the axles will be flat.What the heck are you planning? An extreme off roader?
You are contemplating a G50 in that orientation? You must want the motor still higher, because getting it lower is easy. That is, unless you are running massive diameter rear wheels and need to drop it more than what you would achieve by flipping the trans. OK, obviously a wierdo application!
I see what you mean. Anyway, after some thinking I think there are basically 4 hypoid orientations. I have modded the dwgs as well but unfortunately don't have the priviledge to upload. :shrug:No, not really, I modded your dwg to give it some hypoid & polaced -red- tooth patterns to give you an idea why the tooth angle & shaft loads go all to pot!!!
