Hey Vin! Whats the details on the engine? Block, heads, etc
Man O War 351w stroked to 427, Iron Block - 9.500' Deck, 4.125' Bore, 2.749', 4-Bolt Mains. Borla 8 stacked, EFI and Holley Terminator X. 10.5 comp. Prestige HR 200 CNC aluminum heads, mild cam.Hey Vin! Whats the details on the engine? Block, heads, etc
I will be keeping it simple using RCR brackets and accessories that come with the deluxe kit and installing myself. A ford motorsport short racing water pump has already been installed by Prestige.Awesome! Are you getting them to do the accessory drive or doing that yourself?
Vinny, Nice to hear you are making progress. Did you use spacers on both the front and back? Also, how thick are the spacers you are using? Cheers, RandyI have been working on my RCR40 and I have not been updating until now. I have taken the chassis apart and reassembled suspension, that's pretty cut and dry so no need for details on that. It took some time to set up my rear suspension just shy of 95" to center the rear wheels as much as possible on my +2 suspension. Wheels on the RCR +2" suspension tend to sit way back and not esthetically pleasing.
Report Edit Delete
V
Vinny P
Rod lengths had to be, modified. I am also going to rework the wheel openings for final fitment. I am not going to use the flares supplied by RCR for the rocker panels. I plan on tapering the quarters to blend into the rockers. I also added wheel spacers, so wheels are slightly closer to inner wells, no need to cut excess material off the studs.
Hi Randy, I just used the spacers on the back 3/16" thick. Slight improvement the r/s sits perfect the left side quarter/flare has an odd shape and needs some help. lol. Width of the front wheelbase is ok no spacers needed. My front wheels are very close to body when turning lock to lock, not sure if I will need to go to a smaller front tire to prevent rubbing. Fran quoted me a smaller Avon front tire but sold me a larger one. Don't know why. How is your car coming along?Vinny, Nice to hear you are making progress. Did you use spacers on both the front and back? Also, how thick are the spacers you are using? Cheers, Randy
I am still waiting for delivery. Seems like March, maybe February. I bought my Avons and had them drop shipped to RCR. I ordered them back in September because the future of Avon was uncertain. I hope they don’t get misplaced. Do you have a link for the spacers?Hi Randy, I just used the spacers on the back 3/16" thick. Slight improvement the r/s sits perfect the left side quarter/flare has an odd shape and needs some help. lol. Width of the front wheelbase is ok no spacers needed. My front wheels are very close to body when turning lock to lock, not sure if I will need to go to a smaller front tire to prevent rubbing. Fran quoted me a smaller Avon front tire but sold me a larger one. Don't know why. How is your car coming along?
Thx muchI bought the spacers on ebay I looked up my purchase to get the size it showed they were out of stock. I found another vendor with same item heres the link. https://www.ebay.com/itm/304864152521?_trkparms=amclksrc=ITM&aid=1110018&algo=HOMESPLICE.COMPLISTINGS&ao=1&asc=20210609144404&meid=950370aa70a64f55a1cc7cfc386e317f&pid=101196&rk=3&rkt=12&sd=204036493732&itm=304864152521&pmt=1&noa=0&pg=4429486&algv=CompVIDesktopATF2V3WithQueryItemRecallV3&_trksid=p4429486.c101196.m2219&amdata=cksum:304864152521950370aa70a64f55a1cc7cfc386e317f|enc:AQAIAAABALHyIAEaemKG0mx4REjf%2BHxECBsXtSkNHsCLmXz%2FJyCDeX%2FaDb78456J9CQJiWkf1jzajU677ib6TIsYKbB%2FhCJmqSerIsXBTGu3Gj5r0hoO0J9R41rz99M3uDSjf2A5yNVbHCNqW89v5zcYD6DekswXOtDIR9mmKiLHqMWOIhnq5ghJy3IB7s8aV1UDW4j3P1XJsxvzzgbIRqF3ABh2IG%2FholgR6SLZOo1Lfbi%2BYRri%2FHcHovd2Qk7pRDIshpNGEi5aNDI1FUlmV9d6PN1Aedi0nsyKXWk7Vg1weNjdYV%2F9DwawzPO4j%2FRTCduywoNYMjumnzWwK6ZLcd%2BGwZQGndc%3D|ampidL_CLK|clp:4429486&epid=12003937256
