wheel alignment
does anyone have a good tip on alignment,my car has 225-45-17 front.315-35-17 rear tires.i set it up whith 1,5 mm total front toe ,4deg camber -1 mm rear toe ,5 deg camber but i feel the car a bit loose at speed(65mls and up).
Kent,
I don't know if this will help or not but I was just going through an ERA build manual and they gave the front and rear specs. If you give me a fax number, I'll shoot them over to you. Given my poor writing, I wouldn't dare to try to list them here as I'm sure I'd mistake something.
John
[email protected]
I think your camber settings are way off.
I have set my CAV with 1 degree negative camber in the rear and 1/2 deg. negative in front. Maybe you meant CASTOR? I set 4.5 deg castor in front and 4 deg in the rear.
that is .4deg front .5 deg rear
