Wheel Spinner removal tool
Andy Sheldon
Tornado Sports Cars
GT40s Sponsor
We have now introduced a new tool for use with our knock off wheels.
This tool is designed for tightening and loosening 3 eared wheel spinners and is suitable for use with both types of GT40 wheel spinners including the long and short eared versions.
Its designed to be used in conjunction with either a 3/4" square drive breaker bar or 3/4" square drive torque wrench.
The tool totally eliminates the shock load on one ear of the spinner
caused when tightening spinners using a mallet or hammer.
It drives the spinner at the base of the legs, which is much stronger, as opposed to the end of the spinner which often results in a bent, or even worse, broken spinner legs.
The drive pins are rubber covered to eliminate spinner or wheel damage and the centre drive tube fits into the hub to keep the tool centrally and firmly located when in use.
Use this tool to eliminate the fear of bent and broken spinner legs once and for all. Cost is £195 + VAT
Available exclusively form Tornado Sports Cars.
That is a great Idea Andy, if using a torque wrench what would be your suggested torque setting?
Andy Sheldon
Tornado Sports Cars
GT40s Sponsor
We recently had a customer who had 2 out of the 3 ears broken on his wheel spinner.
Our tool still managed to remove his tightened wheel spinner with just one ear remaining
