JL's RCR GT40MkI Build
Joel Lonky
Day 5: sanding the upper chassis. My plan is to paint most of the chassis black and leave all suspension in machined / natural aluminum.
Do not forget that aluminum, will not stays as new if you are not protect it. It will become dull, foogy and white. It means it will require to be repolished every to or 3 years and when you have parts mounted on it it is difficult to make a clean job. May be you should consider a transparent varnish...
Joel Lonky
Very well aware of that, all alum parts are being coated in Cerakote MC6100
Joel Lonky
Day 6: When you need to flip the chassis and you have no help, used my lift, some lift straps, and a pipe thru the tunnel, instant rotisserie!
Joel Lonky
Day 10: Flipped Chassis over after applying Raptor to bottom, Sponsons and wheel-wheel areas. Glass beaded suspension parts for powder coating:
Joel Lonky
Day 11: Powder coated 39 suspension pieces today. Using Anodized Aluminum Metallic powder. Looks grey in the shop but in the sun it's def Alum metallic. and mounted the front suspension mounts.
Joel Lonky
Yes I used an etching primer under the raptor and sprayed it mixed with 20% slow reducer to reduce the texture (it’s hot in FLA). I do all my own powder coating and Cerakote. I have a Eastwood system for application of the powder. And built my own oven. I have had really good results with doing a base powder and then a super durable clear powder
Joel Lonky
Day 12: clear powder coated all parts with a super durable clear powder. Gave all the parts depth and a good shine.
Joel Lonky
Day 14: fitting fire wall and roll hoop down tubes. Found one of the down tubes were not manufactured correctly angle way out and plates are crooked. Waiting to hear from RCR about replacement before I start chopping it up to fix it.
