302 Oil Pan
The title kind of says it all. What are you using for oil pan for 302? I have a 67 302 out of a mustang and the stock oil pan is pretty deep. Just researching what others have done..
If you're doing any kind of real spirited driving....you should use a baffled large capacity pan. Don't use the stock pan for any kind of track event...just my $.02. If you do, oil starvation could be a real issue.
There's a number of good pan makers out there who do a nice job of baffled large capacity pans....Moroso, Aviaid, etc. They're reasonably priced and worth it.
Personally, I have a Moroso 7.5-quart rear sump pan with baffles. Pretty happy with the quality and fit/finish.
Kevin Box
Canton 15-630 is also an option Front Sump Road race oil Pan
15-644 is a rear sump
Both have 4 gates and good oil control
Rod Dittmar
The Aviaid I have on my engine has 4 gated baffles, side baffles and a top one over all the others. However, I had to modify an outside corner to allow for starter fitment. Hopefully the engine won't mind a few oz. less oil.
Pat
I have the Aviaid pan and the starter just touches the pan. It still attaches to the bell housing but I can’t even slip a piece of paper between them. Worried if I might need to dent it for clearance.
Heat expansion will only create greater contact, so yes, a bit of ball peen persuasion on the pan and some light Dremel work on the starter would be in order IMO.
Or, you could do what Rod did above.
Pat
Yeah I started marking it and will give it a little heat and a ball peen hammer and tap that curve of the starter into to pan. Doesn’t need much really but I don’t like parts not having clearance. Have to check and see which pan from Aviaid I actually have so others will know in the future.
Dave Bilyk
Dave Bilyk
A bit late to the party but fwiw. Since my standard 302 sump was the lowest part of the car and already scraped, I cut the protruding part off and made a new wide base to maintain the same capacity. This was back in 2010. Attached drawings and photos show what I did. I cut and bent the metal sheet, welded in the reinforcement and old sump plug then reformed the oil pickup pipe. Finally welded a reinforcing skirt around it all. I could have chosen a better location for the sump plug as it only just clears a crossmember.
Joep: I did. Very well made and perfect fit. Only thing to watch for is their dip stick is not accurate. They rate their pan's capacity (in this case 6 quarts) for the static volume NOT to include the rest of your system (filter, lines, oil cooler, etc.). I am running 6 quarts plus the nearly 1 quart it takes to fill the filter. That only read mid-way between the low and high marks on the stick. But all in all, a very nice piece. My engine builder gave it the thumbs up.
