Wow Julian - looks very nice. It is also quite different from my older DC&O setup (see pics of a standard RF arrangement & my stripped down one below).
Apart from the T/B differences, I am wondering where the vacuum take-offs are (the old setup had a large vacuum plenum under the centre of the manifold, with 2 take-offs on the top towards the back). In the pic of my setup, one take-off goes to the braided hose at the top of the pic, & the other goes to the adjacent rubber hose. We started off with just the braided hose feeding everything, but had trouble with the MAP readings in the ECU when the power brakes operated - so we added the rubber hose from the 2nd take-off, left the MAP on the braided hose & put everything else on the rubber hose - solved the problem.
Also, you might want to look into a pair of water bleed points at the back of the manifold - the old one had none, so we drilled & tapped them in - they save a whole bunch of trouble with overheating & bleeding. These outlets connect to the braided hose at the bottom of the pic of my setup, & it goes to a nipple on the thermo housing.
Another thing - check the shafts for grooves that locate the circlips which hold the bearings into the T/B's - my shafts had no grooves at all on the shafts & so the circlips moved out, followed by the bearings ! Collets & spacer tubes solved the problem.
BTW, we changed our setup so that the fuel rails run up the inside of the T/B's - this was done to get the injectors to fire almost straight down the throats, rather than around a sharp corner. My engine designer came up with the idea that this would help to get a cleaner burn, & hence have a better chance at getting thru the emissions tests. It was a real pain to make new fuel rails & fit everything in, but it worked - just scraped thru the old ADR-79.01 tests on the 5th try (the only 8-stack ever to do so) !
Kind Regards,
Peter D.
