Not sure if the Yanks are different but the largest compressor that is single phase 240v
is 3 h.p. anything above that will be 3 phase.
They did offer 4 h.p. single phase once but it dont work, you see the amps required to run a 3 h.p. motor is around 12A and In the UK most plug sockets are 13 A fused.
You therefore should put the compressors through a seperate fused supply... Say off your house ring main which is 30A rated.
If you have a long run from the incoming electrical supply to where the compressor will be you can get a voltage drop this will cause an amps increase... It's a balance.
Always buy a belt driven compressor not a direct drive.
Belt drive means motor runs at say 2800 rpm pump is geared to run lower say 1300.
A pump that runs at 1300 rpm will last longer, be larger in size ( working less ) and quieter in operation.
A direct drive motor runs at 2800 rpm , so does the smaller pump run at 2800 rpm hence wears out quicker and bloody noisey.
As I say ask me any questions
