Have you learned 427W's wreak havoc on halfshafts because someone who doesn't own one said so even when Olthoff runs 427s in both cars? What else have you learned?
Since you ask. Olthof told me he could run a 427 in his car because it was a Mk2 and early days, that a Mk1 cannot run a 351 block in historics. The other Mk1s are all running 302 blocks that race and Olthoff has not put his 427 back together.
Olthof also told me that If I was going to be running track almost exclusively the torque of the 427 would wreak havoc with halshafts Cv joints. Fine for the street different for the track. So from a drivetrain perspective a 302 based car is going to last.
I have also heard from same and similar sources that there is a noticeable difefrence in terms of handling with the top weight of a 351 block. Ie there is about 1.3 inches more hgeight and 80 or so lbs in that height, where it is least desireable. Internal rotational mass is more.
Yes a worked 351 powered car is going to be faster to a point, more Hp will sort of do that.
I seriously doubt that most drivers below the leverel of Olthoff can really exploit the extra power that a 351 based motor can put out on track. The hard track driven amateur cars seem to be in the 400's hp range.
The limitations of a 302 are weaker block, which is cured with aftermarket blocks, and the need to spin them to make power, which requires stronger and more expensive internals. It also means you end up with a more racy motor for your track car.
So yes for a street driven car there is no doubt that a 351 is the way to go. More reliable power, less expensive. On the track, and most tracks are not lemans, something that can brake and turn better may well be more rewarding to drive and you may well go faster.
The question to me is it worth going further with an aluminum block, and will this greater loss of weigth affect known chassis setups.
Simply put, you cant race a mk1 with a 351 motor, and with todays tech a fully worked 302 may be quciker on track, and will certainly lead to a longer lived drivetrain with a more "authentic to Mk1" sound and rev range.
The motor specs for me look something like 530 hp at 7200 rom and about 470 ftlbs of torque. So this is less than a 427 and you need to spin it more.
