Andrew Robertson
Hi All,
Mclaren M1C replica, race only on slicks, about 900-950kgs with me in it, 40/60 weight dist, 17x9 fronts, 18x13 rears, Wilwood Superlite 6 pots with 4.04 sq/in piston diameter on both front and rears, and same 353mm rotors front and rear. Wilwood 6:1 ratio pedal box. Want a firm and short-ish pedal and don't mind effort as long as I can brake to the traction threshold at will.
After searching the archives seems it's very application specific, with 3/4 bores seeming too soft for several posters. I was leaning towards starting with twin 7/8, or maybe 7/8 back 3/4 front, and dialling in from there.
What do you think?
Also, what size clutch master fully strokes the Wilwood pull-type slave?
Thanks, Andrew Robertson
What do you think?
