I'm currently musing over the "best" way to attach these plastic pieces.
Option 1 is to RTV them in place - not my favorite way because i prefer everything to be as easy to remove as possible.
Option 2 is to use a low profile buttonhead that's powdercoated black (not black oxide) in 4 locations.......probably held in with a rivnut
Is there an option 3?
Obviously 1 is better if you want it to be sealed, but it makes removal a pain. Option 2 is better for removability, but doesn't look as clean (although i don't think having several black buttonheads will make it look unclean against a white body?)
Also, would you feel comfortable holding the windshield in with just 4 screws? I've been studying various setups and noticed some race cars use 4 tabs to hold it in place, but the tabs look a bit out of place on the car.
edit: Also, if going the screw route, can I use metal screws, or should they be nylon?
