Jim Rosenthal
Here's a question, or questions, that someone on this Forum would know the answer to...
How do you decide how much braking capacity a performance car needs; I know it is a function of weight, horsepower, axle ratios which imply top speed, but how do you decide it?
How do you decide which master cylinder size to use with your calipers once you've figured out how much braking capacity you need?
I'm sure there are formulas or rules-of-thumb for all this. I should mention; my car will likely have the same AP brakes that were fitted to Safir cars, and somewhere there is a master cylinder spec etc for that. But it started me thinking- how do you determine that the car is going to stop when you push the pedal? /ubbthreads/images/graemlins/confused.gif
