I've been looking around for a carb to go on my Lola motor. Motor specs currently are:
342 inch SB Ford
AFR 185 heads, custom CNC porting job
Solid Roller Cam
0.676" lift Intake, 0.673" lift Exhaust
Duration at 0.020 287 Intake, 295 Exhaust
Timing @ 0.050" IN Open 18 BTDC Close BTDC 58
Timing @ 0.050" EX Open 61 BTDC Close BTDC 21
110 Lobe separation
Comp Cam Valve springs and titanium retainers, 600lb open, 260lb seat
Funnelweb single plane intake - if we use 4bbl
I'll probably leave the motor as is to cut costs on the build a bit - I'm poor, don't know why.
However, in speaking with Barry Grant, company that does Demon carbs, they recommend a 675 Race version with removable venturis. That carb can flow up to 737 cfm of air which should do the motor to about 7800 RPM or so. Plus, they have the removable sleeves that are nice for adjustment. Problem is, this carb goes for about $1000 - quite a bit more than I reckoned. That, plus the manifold, lines, etc. it'll be about $1400 all told.
That isn't too far off, relatively speaking, to a set of webers. Of course, back to the same old argument on the webers - I don't think a 48mm weber flows enough for a 34X inch motor at 7500 RPM as we debated last year.
Any ideas, suggestions, or connections for a Demon carb on the cheap? I will look at some alternative carbs too.
R
342 inch SB Ford
Solid Roller Cam
110 Lobe separation
R
