While driving the CAV today the clutch pedal felt much stiffer than usual and engaging gears and disengaging gears became quite difficult.
Clutch pedal was always stiff and gears engagement was always a bit notchy but now it is imposible.
Trans now grinds into gear even when clutch is fully depressed.
I bled the system with my vacum pump and lengthed the slave cylinder rod slightly to see if the shifting issue would improve,
Absolutely no improvement. Clutch is also grabbing now.
The trans is an RBT ZF 5 speed.
Appears to me that I need to remove the trans and inspect clutch/
pressure plate etc.
Any advice would be welcome.
Thank You
pressure plate etc.
Thank You
