In order to finish up the wiring, I needed to install the shifter because I want to have a little switch panel on the side. Most of the track days I attend require a point by or a signal. This is a very convenient place for the signal toggle.
The cables went in very easily and fit perfectly.
I had to grind off the balls that were riveted to the shift linkage.
Then I just had to bolt in the cables. The hole in the linkage was larger than the stud end on the cable so I used a little bushing but other than that, it was easy.
The cables run to the back through the tank and under the engine on the passenger side. The shifter sits nicely on the center channel but I wanted to adjust the position just a little to make it perfect. I needed to fab up a mount for the shifter that would give me a little more hieght and tilt.
Once mounted, I was able to attach a piece of aluminum angle on the side and wire in a few switches.
I have the turn signal switch first right were I can easily reach it for a quick signal (not that i will ever need it!) The hazards are the next switch and the horn is the next button just to let the guy in front of me know I'm coming around!
