Docking Radiators Have you had a Failure?
Dave Bilyk
Dave Bilyk
Hi Phil, I plugged them for now, but before I did that I found that they weren't drilled through. So to create a bleed point I drilled them through and plugged them with a 6mm bolt and copper washer. In the course of filling the system, I used one to allow air out of the rad.
Dave
Dave
Ok good to know. I’m going to use the one on the driver side as a bleed line to the cap on my expansion tank so need to find a fitting with 6mm thread and a 10mm hose.....that could prove fun.
You got photos of your fitted, I’m guessing you inlet and outlet and at the floor
Dave Bilyk
Dave Bilyk
Just one more comment, the pipe stubs are a little smaller diameter than the Docking so make sure you use tubing which is a snug fit.
