Holy Moly! I'd have one just for the bragging rights, but the first ad is for a "non restrictor plate" motor. What Nascar Series would that have been for? For $13,500 - I'd have a go..
For road racing, not sure that the cam/head combination would work too well though....
Aren't these built for flat out 500 milers? By detuning I would have thought they would be reliable and they always use the best parts for sure....
In a misguided attempt to slow the cars down on the superspeedways such as Daytona, certain races are run with restrictor plates between the intake and the carb. Special motors are built to try to extract the most power with this severe limitation. The advertised motor here is a 'regular' engine, meaning it makes substantially more power. It will also have about 14:1 compression!
The camshaft is probably profiled to produce top-end power at the expense of everything else, so this motor wouldn't be very flexible on a road course, and would be useless on the street. However, a simple cam change would probably improve things radically.
What would be best would be to find one of the engines specifically built for the two road courses that NASCAR runs (Sears Point and Watkins Glen).
While there's no doubt that these race outfits are selling off old engines that have reached the end of their useful life as top-tier racing motors, the quality of the parts inside is outstanding, and they would probably be fantastic at our boy-racer level. The cost to build such a motor from scratch might easily top $50,000, so for sure they represent a bargain.
Having said that, maintenance costs are likely to be quite high, as critical components 'time out' If these engines are raced, valvesprings will need to be changed frequently, and the motors will probably need to be completely gone through every 25-50 hours, tops.
But as a foundation for a detuned street motor, i.e. fitting a less radical cam, and lowering the compression with different pistons, it may be a great place to start.
An even better choice would probably be a NASCAR Busch series motor. These are built to the same standard, but the series has a 10:1 compression limitation (or something like that), which makes them pump gas-friendly. Or so I've been told--I'm happily corrected if necessary!
