Exhaust bracket
Sean Starkey
Bumping this old post to see what everyone is using for the hold down springs these days. Looks like the previous links in this thread are all obsolete.
Im trying to source these type of springs to hold my pipes in place.
Adrian Starling
Try these guys Sean!
Sean Starkey
Nice, thank you Adrian!
This post is to replace what Photo-bukit Hijacked..
I didn’t see the need for springs, so I mounted my mufflers to a bracket with T-Bolt clamps. The bracket was mounted to a bracket on the transaxle via Insulated Fiber washers to minimize heat transfer from the mufflers..
Since my old website is now long gone - I only have a handful of photos to share here..
Sean Starkey
View attachment 134052View attachment 134053
Im interested in this oiling system for the G50 now. That looks really cool. Do you have more information on it? Is this something you designed or a kit?
Designed myself. Drilled and tapped directly above each gear set. The fittings were 3/8 NPT to my recollection. There were restrictors added to the fittings that had .030” holes in them.
The pump was a 12v Moroso gear lube pump like what’s used in NASCAR differential coolers.
Sean Starkey
It definitely came out looking great sir!
Dang it, now I want to add one. :rolleyes:
Thanks I appreciate that - but you’re going to have to have the case “empty” to drill and tap it.
While I designed the system, the new owner of the car, Mitch Krause did the final plumbing..
