Chris Duncan
Running AFR 165 heads on a '92 HO 302 roller block.
Using the AFR recommended gaskets.
head gasket #1011-2
intake gasket #1250
Early on I was getting some coolant leakage at the corners of the heads. I thought it was because I was running straight water and it corroded either the block, head, or the gaskets. Recently I tore the engine down and when removing the throttle bodies was surprised to see the intake gaskets were not port matched anymore, when I knew I had carefully lined everything up they were now sticking out 3/16" in places.
After pulling the intake manifold I found the intake gaskets totally shrunk, to the point where they have split at both ends and have large black soft carbon tracks indicating leakage through the splits.
Further removing the heads I've pinpointed the leak at the head corners. It seems the strips of blue sealer on the gaskets do not line up on all passages on the heads and on the block.
Sort of disappointed with Fel-Pro at this point as this engine only has 1500 miles on it. I do have to admit that during setup the engine temp briefly got to 225 F at one point due to inadvertently leaving the electric water pump disconnected. But it doesn't seem like this should have caused all this failure especially the sealer line-up issue. The intake really moved due to shrinkage but the head gasket doesn't look like it moved, it was mis-aligned from the start.
Does anyone have any recommendations for head and intake gaskets other than FelPro? Or maybe a different FelPro part number?
head gasket #1011-2
intake gasket #1250
