Fiero with longitudinal Audi V8
i am building a better bracket for the 2 idler pulleys i just need someone to weld the Aluminum
ok a few new pictures of it on the engine cradle and now in the car . i had to modify the firewall by moving it 2 inches at the top for clearance due to the blower pulley and now i have started the wiring that should not take to long and i should be able to hear it run in a few weeks
This is turning out to be quite the project Mark... Nice work!
Great job Mark! Yup, she's running just a bit rich, but kudos to you for getting all the wiring and ECU sorted to get this far!!!
it gives me a sense of pride like all the folks who build something you put your heart and soul into it so it feels great when your peers approve of it
well have been woking on the car and have put a testarossa rear body on it since it was cheap and it widens the back so i can put 315 35 17 on it
Good to see you back on the project Mark!
Have you considered ditching the Testarossa strakes in the side vents? Might look a little less "kit-car" like...
Mark - I think you did the right thing... And yes, it will be a beast!!!
Yaaa the body filler work is done now i need to just sand the whole car with 220 then since i am trying to do a really nice paint job i am going to spray high build polyester primer then block sand with guide coat to get it as flat as i can then use regular primer sand and put down color . I must really get the floor swept up and all the dust off the car and i will wet the floor to keep the dust down when i spray the color and the clear
i just put some cheap spray can primer on to see how it is coming and i think it is looking good i do need to work on door alignment but it sure is better then when i started
