Hi Troy,
First thing I must do is appologise for my comments....They were totaly
inapropriate for this forum. I had a few too many beers down the pub and I made a fool of myself .You had every right to verbally attack me for my comments. But chose not to, so Thank you.
I didnt present my views very well in that post, but I will try to now.
The idea of building a flat plane crank,is as Rudy says, "thinking outside of the box", and Im all for something like that. And I really hope you are seccesfull with this project. I also think the LS series of engines are very good.
When you started this thread your idea was very simple , and in my opion possible. You then said you would like to take the power up to 450/500hp, which by all accounts is very possible with these engines. The result would be a fast road engine, and if I was doing your project, then that is what I would do...There would be little point in building a flat plane engine that was totally standard
At about this point, you started talking about a short stroke engine, then when you got your programe, all of a sudden you went from a fast road engine to a High Revving, Short Stroke, Full Race Engine, That would need huge amounts of money, and time to develop.
I think you are trying to do too much in one go.I would do the engine in stages
First Stage ......get a low milage LS engine, and tune it to a fast road spec, experiment with headers, and get all the components working in harmony with each other
Second Stage.....add your flat plane crank and cam, with the same profile as your first cam, and see how it compares with the dual plane crank
If the engine is a bad engine, put the first cam and crank back in, and you wont have lost much, but you will still have a good engine
If the engine is really good, and you want to develop it further, then sell the engine.(you will get your money back..you may even make money).
Third stage.......Build your high revving, short stroke engine. By this stage , you will have a much better idea of what cam profile you will need, and also you may decide to make a lighter crank
The point Im trying to make, is that by going through the first two stages, you will have a far better idea, of how the engine will perform, and what is required to make a high revving, short stroke, engine that will give the performance and sound that you want.
I am "pissed off" with myself for the comments I made, as soon as I hit the ...Submit Reply.... button I knew I had done the wrong thing...
Sorry guys
