Mick
When I put in the information to caculate the numbers I need to give it a range of rpm. I start with, lets say, 2000 and go to 8500. I am allowed 10 rpm points so I need to spread them out by about 600-750rpm depending on where I started. Now I just ran my engine from 7000-8000 and did 100 rpm, so starting at 7000 I got 595,600,604,608,613,616,618,617,615,609. So when looking at that I can say I got 618 hp at 7600 rpm. So I can call my car the SL-C 618. Haha
I took an LS1, took off the acc and threw in a header with exhaust. With the cams I cam up with almost the same numbers, but third cam did not go as high and went flat from what they had. I think the intake might be a real limiting factor here. Might have been too much cam for the engine specs. There are so many little things to put in and not having all the specs can be hard.
Now I learning about what rods and pistons to get. Oh the fun. Which con rods to get and which pistons. I have decided on the 3.905, -2 to -4 dish flat top with reliefts, .927 pin. I need to get pistons before the rods so I can get the right ones. I am gathering info the differnt pistons on weights and what to choose. I have this list, JE, Wiseco, Mahle, CP and Diamond. I am looking up weights.
Mahles look nice so far. Lightest, forged, comp height is ok. Some of the lighter pistons have a really small comp height so the weight savings is offset by the con rod length and added weight there.
I could also just have the piston deck height higher with a longer rod instead of shaving the head to get what I want. Choices.
AI emailed me finally so I will talk with them about what they think would be the best combination.
