Joel K
Been a bit, but things have been moving along at a slow pace.
Got the steering installed, that’s a minor technical feat for someone who never really understood the intricacies of vehicle steering setup. Time will tell if I got it right.
Counting the rotations lock-to-lock, centering the rack, then centering the housing on the body left to right took a lot of measuring and then re-measuring. Pretty sure I’ve got it centered within a couple millimeters, nothing the tie rods adjustments won’t fix. The angle of the tie rods to the upper and lower control arms is a whole ‘nuther issue. I mostly aligned it with the lower control arm, but slotted the mounts so I can move the rack up and down just a little when I get the suspension set up better and check what works best for bump steer.
Lol, wouldn’t you know it, I forgot to take the mount off before loosely bolting it on, so now I have to take it apart again to take the mount off off because I can’t fit a wrench behind it. View attachment 153019
Jeff,
There are multiple threads on bump steer. You may need spacers where the steering rack arms connect to the uprights. A common way is to connect it all but remove the shocks. Then run the suspension through its travel and add/remove washers to minimize change in toe. Then fab a spacer the height of the washer stack if you like a single spacer.
