I installed the Ford short pump when I put my car together last year. With 1500 miles on the car (a lot of track time) the impeller broke off the hub and was laying in the bottom of pump. This event happened at my last track event at Thunder Hill. I was meatballed off the track because the car was steaming. The pump looked fine externaly but I knew water was not circulating. When I removed pump the broken impeller was apparent. Ford Motor Sports replaced the pump at no charge.
I was talking with Larry Stock of Pantara Parts Connection and he says my pump makes the FOURTH :sad: impeller failure he has heard about. So if you are having some funny cooling issues consider this:stunned:
The impeller is thin, about .075 in. The other impellers I measured are .095 in. So heads up guys.
Randy
Randy
