Rick,
I’m not surprised to hear that you have different handling characteristics having discovered for myself that the car is very responsive to variations in setup. If you read the thread on rear-end geometry (as directed in Clayton’s original post) you’ll find that the consensus there is that the RF40 is very tail-happy, to which I have vigorously disagreed, so I’m glad to hear that someone else here has found this not to be the case.
I did make a passing comment though in my last post that the rear end fell away more quickly than the front as the track got warmer. Just to expand on this… With no changes to the settings, the car’s balance changed considerably through the day purely as a result of changing track conditions (everyone on that day was commenting on how slippery the track had become as a result of the track getting warmer). In the cool of the morning I was countering the over-steer by powering through the corner. In the heat of the afternoon, more power would only result in more over-steer… quite different. This bothers me a little because I have been trying to make comparisons between a settup at one track and a different settup at another. Now I’m starting to wonder how much can be attributed to the track conditions.
Anyway, I’ve rambled a bit here but to get back to your original request, I don’t have any setup figures as such because I’m still going down the path of making wholesale changes before each meeting and just keeping notes on what I’ve done… the intention being that I will take a full set of proper measurements once I am reasonably happy with what I have.
I can tell you this much though…
On the front suspension, I have cranked up as much –ve camber as I can get (which is not all that much really) and gave it 1mm toe-in (as measured at the rim of a 17in wheel). Shocks are set to 3 clicks from max stiffness. I’ve made no attempt to alter the castor at the front, but maybe I had a lot to start with. If I do, then that would result in more –ve camber on turn-in and explain why I have good grip and the scrub pattern on the front tyres seems to be even across the entire tread.
The rear is the area that I’ve spent most time on. I’ve mentioned this before so I won’t go into a lot of detail other than to say that I have set it to 0 toe at full bump (which results in 0.7deg toe-in at rest) and 0 camber at rest. Rear castor is set to as much as I can get with the standard suspension. Shocks are set to 7 clicks from max stiffness.
Can you tell me what size tyres you are using Rick? This might be the biggest difference. I’m using…
Falken FK 451 (road tyres)
Front 225/45 R17
Rear 275/40 R17
NB. I expect that the settings to be quite different for stickier tyres but I too am looking for a stable starting point before changing to stickies.
Also NB. I'm running an LSD which will also make some difference.
Clayton,
I’m using Race Brakes RB74 brake pads which are a vast improvement on the standard pads. Can anyone tell me how they would compare against the Ferodo DS2500’s? Incidentally, I was competing against a 1700kg Corvette with identical brake calipers to mine (I'm running C4 Corvette calipers) and his brakes were not cooking nearly as quickly as mine. I think brake cooling is next on the agenda.
