S Steve Sandoval Jun 26, 2017 #1 My fuel sender has two terminals labeled M&T - which one is for ground? Never seen a fuel sender labeled as such, thanks -Steve
Rick Muck- Mark IV GT40s Sponsor Supporter Jun 27, 2017 #2 Does not matter. The sender is a "resistance" unit and measures Ohms across the terminals. Test it with an Ohm meter before you install and you will see it work either way.
