Time to tackle the brake lines.
For a few reasons I decided to run my own brake lines instead of using the supplied stainless lines:
1)Unfortunately I stored some of the the brake lines in the basement crawl space and after 2 years the flare nuts rusted up really badly. Even after cleaning them up with a wire Dremel brush I was concerned they are really too pitted and should not be used.
2)Having installed power brakes, the lines needed to be modified anyway.
3)The clutch line interfered with the power brake vacuum bulkhead fitting in the front compartment. Did not plan that one out very well.
4)Not crazy about having the unions for the rear brake and clutch lines in an inaccessible location along the side of the chassis.
5)Having a fully customized set of lines is nice and always enjoy learning something new in the process.
The stainless brake lines that come with the kit are really nice and if my build was a standard config and I had not ruined some of the lines I would definitely have used them.
Video of fabricating and installing the brake lines...
So here we are, following a few other builders who swapped over to NICOPP and recommended it so decided to go in that direction.
Tools used for the job:
Titan 45 degree 3/16” Flaring tool
Titan Mini Tubing Bender 51503
K Tool Flare Nut Wrenches KTI4450
K-Tool 37 degree flaring tool
Speedway Motors 3/16 Inch Handheld Tubing Straightener
Harbor Freight Tube cutter
General parts for the brake lines:
50’ SUR&R Ultrabend 3/16” NICOPP Line
Speedway Stainless Flare nuts
ARP High Temp Hydraulic Thread Sealer 100-9904
Speedway 3/16 Stainless Steel Single Line Clamps, Pack of 12
Part #: 91031315-3/16
Speedway Dual Line Stainless Steel Line Clamps, 3/16-3/16 Inch
Part #: 91031316-3/1
Specific parts to connect the 2010 Camaro SS Power brake master cylinder:
AN3 to M12x1.5 Inverted Flare Stainless Steel Brake Fittings
Speedway Stainless Steel -3 AN Hard Line Tube Sleeve 2 Pk
Speedway Stainless Steel -3 AN Fitting Tube Nuts 2 Pk
Wilwood 260-8419 Brake Proportioning Valve
Wilwood Residual Pressure Valves 260-13783 to replace the supplied residual valves.
Decided to tackle the front brake lines first.
In general, I used the existing lines as templates and adjusted each piece to accommodate a number of slight changes. Used the tube straightener on the first section of tubing. Starting with straight tubing enables you to make nice crisp brake lines. It worked great...
Used the Titan mini tube bender and Titan double flaring tool which also works really well. Pic of the first NICOPP line, the drivers side front line is looking good...
Mounted the power brake proportional valve. Following in Johan’s footsteps and installed the proportional valve to the front brake circuit to help dial in the brake bias. Using a brake bias calculator the bias with Camaro master cylinder is around 63% front and 37% rear with no adjustment.
Pic of the front brake lines and tee installed. Had to modify the front passenger line to clear the AC #6 fitting...
Fabricated 5 brake line hose retaining tabs. The taller ones are for the rear brakes, the shorter are for the front brakes and the clutch line...
Moving on to the clutch and rear brake lines. Ran the clutch line through the side of the foot-box vs. the front of the extended foot-box. Easier to reach the soft hose in case it needs to be serviced...
Also relocated the brake line to behind the lower control arm fork. This makes installing the brake line through the front compartment easier...
Moving on to the front section of the rear brake line. It is a single section back from the front compartment down to the junction tee on the rear frame rail. Pic of the clutch and rear brake lines showing the elimination of the brass couplers along the side of the chassis. Using dual line clips makes for a clean install...
With regard to the rear brake lines, I was thinking about running them and the clutch lines parallel all the way down the side of the chassis instead of running the rear brake line on top of the rear frame rail. I guess this is done to better protect the rear brake lines from getting damaged by road debris or some other mishap. Not totally sure, but ultimately stuck to the original design and placed the rear brake lines on top of the frame rails.
Also stuck to the original design and routed the right rear line across the rear frame rail over to the passenger side. Another change was to the clutch line. Moved the kink from the rear of the line to along the tub so the clutch line sits higher along the rear frame rail...
Used a dual bend to snake the line behind the dry sump tank...
Installed the brake line hose retaining tabs with M5 screws. Pic of the rear brake and clutch lines. On the clutch line end I used a 45 degree double flare vs. the 3AN female fitting that is used by the factory. This way I could use the 3AN to inverted flare brake line adapter which came in the kit and a mounting tab to secure it to the chassis...
Installed the metric inverted flare fittings to the master cylinder. They expose a 3AN male fitting. I could have used 3AN flex lines or a 37 degree flare hard line coming out of the master cylinder. I chose the latter with the Speedway 3AN to 3/16” hard line adapter. Also used the K tool 37 degree flare tool to finish the job. Pic of the front brake line components including residual valves installed. Nice and neat...
All in all I am happy with the end result. Time to move on to the parking brake caliper install.
