Jim (J-6),
I am trying to figure something out and would greatly appreciate your help.
In one of your posts, you mentioned that your car ran a 2.50 ring & pinion at LeMans.
What ring & pinion ratio did it use at the other races where they didn’t have to gear for top speed?
Second, I believe that the T-44 had the close ratio gears. Is first 2.32, 2.22, or something else?
And last, if you happen to know without having to go and measure, what is the diameter of the rear tires when the car is fitted with the proper racing rubber?
Thanks for your help,
Kevin
Kevin
