Tim Kay
Ok, time to bring in my pinch hitters. I’m at the bottom of the ninth with 2 strikes, actually more strikes than I care to think. So here we go, hope you guys can help.
No spark at the plugs thus no fire, not even a short fire, nothing.
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com
Components: AEM ecu, MSD 6A with blaster coil, Accel electronic distributor, TWM 8 stack fuel injection.
<o
></o
So far:
1. Fuel pressure is normal
2. Injectors seem to be working
a. Plugs get damp with gas
3. New set of plugs
4. Emptied gas tank and filled with fresh fuel
5. Plug wires are good quality
a. Less than two years old
6. Tested MSD
a. per MSD’s trouble shooting instruction I get a real healthy spark at the coil wire (end that
pops on to the distributor cap)
7. Rotor appears fine
8. Distributor cap appears fine
9. Sent AEM ecu in for diagnostics, apparently, fine.
10. Remove and ground spark plug, turn over the motor and no spark.
<o
></o
Circumstance: Driving normal for many miles, stopped for gas and one mile later the motor died (no popping or missing, just died like fuel pump shut off). Would fire and run smoothly but no more than 30 seconds. I thought the gas may have been bad, see #4. Repeated attempts to fire would reduce to no fire at all (again, no popping or missing). Next day or two I could start the car in the morning with same result, fire for 30 seconds then not at all. Now it simply will not even fire.
Suggestions...
<o
So far:
3. New set of plugs
6. Tested MSD
<o
Suggestions...
