I have been struggling with how to use my “drive by wire” accelerator pedal and not have to use a stock coyote intake. The stock intake looks terrible and doesn’t even resemble old school gt40; but that’s not as important as developing an air intake that doesn’t have to go into the driver compartment.
I could get get a Borla 8 Stack, but $6,000 is a lot of dough. Even the other packages are at least $4,500. I would rather spend that money on something other than an intake that won’t allow the coyote harness and pedal. That’s one of the silly things that I really like about the coyote; you don’t have to worry about running an accelerator cable, you can tuck the wire for the coyote pedal anywhere.
So here is what I came up with and I would love to hear your opinions:
I bought a Holley Sniper manifold for EFI. I also picked up a LS 4150 carb/efi adapter. Then I picked up some aluminum stock and I’m going to fabricate an adapter to attach the stock coyote throttle body to the LS adapter then to the manifold. Therefore the stock harness and all wiring and pedal are still all good!
You need to use the LS adapter because the stock throttle body is designed in a way that it cannot be mounted directly flat to the adapter, there is a part that sticks out so you need to make another adapter.
I’m sure you could manufacture or fabricate something slick, but that’s beyond my ability.
For looks I am adding an old school oval air cleaner.
Here is a mock up. The air cleaner will sit about 1-2 inches lower after I make a flange to fit the air cleaner.
I also added a gt40 with a stock coyote intake for comparison sake.
Let know what you think, it’s not perfect, but it’s better than using the stock intake.
