Jim,
They will fit, but they are probably not much better than the bf goodrich radial TAs that came on the roller. Probably comparable to a Kumho which is not a bad tire. Cars under 2500lbs need VERY grippy tires to stick/corner well. I don't think Jegs/Summit list the tire durometer/wear specs, but when looking at tires on websites like tire rack etc, you can look at the specs. (what Chuck is referring to) Generally softer compound/high wear= sticky/track type tires. Keep lookin, Scott
