PeteB
Made some progress this weekend - got the brake lines installed.
I decided to use rivet nuts on this build. During my last car build, through much experimentation, I discovered the difference in the amount of torque required to tap a hole and the torque required to break the tap is approximately 0.00001%.
Unfortunately, my cheapo rivnut installer I bought at Ace Hardware broke about halfway through the brake line install, so I went back to tapping holes until the new tool I ordered from McMaster-Carr arrives.
It took me a while to figure out the brass fittings that come installed in the residual valves have to be removed. The smaller one is glued in and is a real pain to get out. I broke one of the pre-installed fittings trying to unscrew it and had to drill out the middle and use an easy out to get it out.
The access holes in the footboxes sure make working in the footboxes easier. Here's the lines inside the footbox:
Front outside the footbox:
Line to LF caliper:
Down the side:
Rear section:
I made a bracket from some aluminum bar to mount the line end to frame at the LR Caliper:
Pretty much the same on the other side. Next up, coolant lines.
Line to LF caliper:
Down the side:
Rear section:
