Pete B's Build Thread
PeteB
Back end of the Graz looks much better now:
Heat gun made removing the black crap much easier.
PeteB
Just took the SLC for a short drive. The Dakota Digital GPS speed sensor seems to have solved my stalling issue and the speedometer is working great too.
I added some daytime running lights and LED halos to the headlights during the winter. Still need to repaint the headlight area black, but the weather hasn't been cooperating to get any painting done:
They're not quite as useless as the mirrors on my Cobra were, but they're pretty close.
They need convex mirror glass to get the most out of them. I made mine from cheap replacement mirror glass I got at Autozone that were supposed to be for a Chrysler minivan. They cost $18 or so. Just trace the original glass on the replacement glass, and carefully cut with a glass cutter. Sand the edges carefully and you are done.
I also modified the housings on mine so that when the glass was adjusted correctly, the edge of the mirror glass was still inside the housing.
With these mods, and a full-time rear-view camera, I have no blind spots.
PeteB
Added some Howard Jones snap vents tonight. They look like they should work well - I'll try them out tomorrow on the way to Cars & Coffee.
Downside is the manufacturer states they ARE NOT RECOMMENDED for speeds above 120 knots, so that'll limit the top speed when they're open :laugh:
Closed:
Open:
Pete,
Do you plan to leave the hole cut in the street tail to accommodate the Graziano, or do you plan to do some fiberglass work to close it up? I guess I haven't seen any finished pics of bodywork with the Graz installed.
Is this what most people do? I have seen some video walk-arounds of Graz installations that look different, but I can't identify what exactly has been done. I have searched for more pics but have been unable to find any. Any help?
I fiberglass over the cut out either like in the picture or fin to fin.
PeteB
As far as I know, Allan is the only builder so far who's finished a car with a Graziano, so there is no "what most people do". On your build, do what you like.
We have actually built cars with Graz transaxles too
Raver races their slc with a Graz trans too
There are more out there running around too
PeteB
Fran, just curious, have you closed off the hole on the cars you built or left the back of the transaxle sticking out?
I'm leaving mine the way it is. I don't think it looks bad, in fact it's rather race car-y.
Part of the beauty of the SL-C is you may let your imagination go wherever you choose.
I prefer the race tail open and the street tail closed myself.
PeteB
The big brown truck brought my new style hinges from RCR today. A test fit revealed its going to take some rework to the back end to get them to work, but I think it'll be worth being able to open the rear clip enough to work on stuff back there. I'm going to have to cut the crossbar on the rear clip to provide clearance for the Graziano and figure out how to reinforce the rear clip.
Here's the new hinges:
