PeteB
I've been having overheating problems, so ordered some Maradyne fans that Allan recommended, http://www.summitracing.com/parts/mar-m122k
Stock fan on the right, new fan on the left. It certainly looks more powerful!
Got them mounted tonight, but still have to do some wiring. I fried the fan circuit in the ISIS Mastercell because I followed the directions and wired the 12v output from the GM control box directly to the Mastercell input. So, I wired the fans directly to the battery through relays controlled by the GM output. The unintended consequence of this is when the fans are running, they don't stop while the starter is cranking. I am going to use another relay to cut the fans out while the engine is cranking, but to do this I've got to run a wire from the starter solenoid all the way up front to the fans.
