Pete B's Build Thread
PeteB
Pete - I'm thinking I would like to give plasti-dip a shot while I'm shaking the car down and maybe even as a permanent solution. Based on rough numbers using the DYC website I come up with 250-350 to paint the car. Seems a reasonable cost and something I can do every year or two if I get bored of the look.
Can you give a few details on the equipment you used? Did you build a paint booth or just have at it in the garage?
I've been spending some time on the DYC forums and watching their YouTube videos, is there another/better online resource?
Cam, I used the standard spray gun from DYC and did it in my garage.
The Dipyourcar Community group on Facebook is much more active the DYC forum.
Hi Pete. Are you happy with the Kirky seats? I am seriously considering them. What width did you buy if you don't mind me asking. I think Ill need 17's.
Does anyone know the width dimension of the stock seats? They are a little tight in the rear! I purchased my car second hand. It was from 2013 originally.
PeteB
I'm quite happy with the Kirkey seats. Mine are 16". They're snug, but that's how you want them to keep you from sliding around while cornering.
PeteB
Went for a drive this morning. The new springs make a HUGE difference in the ride quality. It was a little bouncy though so I need to adjust the shocks.
PeteB
I added an ignition button to the dash and re-wired the start button so I can turn the ignition on, then turn the engine over by pushing the start button. To do this, I disconnected the ISIS "one button start" wire and connected the "ignition" wire to the ignition button and the "start" wire to the engine start button.
An unexpected result was the engine start button was now live even with the ignition off. To fix this, I added a relay to provide an ignition on ground to the start button.
I used a LED billet button that I had left over from my Cobra for the ignition:
PeteB
Finally got around to installing the splitter tunnels AJ gave me.
I kinda guessed on the placement, but they really can only go a about half an inch left or right from where I put them. I angled them a bit to match the curvature of the back of the splitter.
Hole marked:
Cut:
Tunnel installed:
I used epoxy, rivets, and four 1/4" bolts to hold it on. Needed the bolts because the flanges on the tunnels aren't flat and needed to be pulled down to meet the splitter.
PeteB
Finished the other side tonight. Not sure if they will make much of a difference without the fender vents, but since I had them, might as well install them.
They will help at higher speeds , as you say the fender louvers help too
With our race cars or serious track cars we put one inch of rake in the car from front to rear axle centerline too
PeteB
Looks good. What are the pieces mounted on the top of the tunnels?
Fran is correct - those are trailer plugs for connecting the headlights, marker lights, and turn signals. Makes removing the front clip much faster.
PeteB
Installed a LED bar on the license plate tonight. Just need to aim the headlights and I'll be set for some night driving.
PeteB
Went to a cruise-in last night and talked to a guy who runs a vinyl wrap business in Cincinnati. Since the place in Indy blew me off, I'm going to have the wrap done by Cincy Vinyl Wraps. They had a wrapped Z06 and Camaro at the cruise in. Both looked amazing.
PeteB
Drove down to Cincy today to talk to the guys a Cincy Vinyl Wraps. We came up with a plan for the wrap that is going to look awesome. I'm going to peel the Plastidip and finish the bodywork after LS Fest, then get the wrap done in the Oct or Nov.
Observations from my first 100+ mile trip:
1) I need to get the windows tinted. The A/C is blowing cold air, but when the sun is beating down on you, you're still hot.
2) Need more insulation on the forward firewall. Lots of heat coming in from the radiator. A/C wasn't keeping up. It was 97F out, so it was an unusually hot day.
3) Got got caught in a short but intense rainstorm and found out where all the leaks are. I've got significant leaks where the roof panel meets the rollbar in the front. Not really sure who to get this completely sealed.
4) Driving this thing on the intersate sucks. I'm beat after 2 hours in the car. I'm thinking I'm going to try to borrow a friend's trailer to take it down to Kentucky for LS Fest.
5) Trans temp is a little concerning. It was up to 202F when I got home.
PeteB
I been playing around with mounting locations for my GoPro before my track day next week. Here's a video of a drive in the SLC. Not a very exciting drive stuck behind slow traffic most of the time, but you can see how my long range rear view cam works.
[ame="http://www.youtube.com/watch?v=RjGIPQenGt0"]http://www.youtube.com/watch?v=RjGIPQenGt0[/ame]
PeteB
Built a shroud to deflect the hot air from the radiator away from the forward firewall. Hopefully this will reduce the heat coming into the cabin.
Pete,
I created a very similar shroud but I found it was still getting quite warm in the cabin from the radiator. I bought a roll of reflective insulation from Home Depot and ran it behind the shroud covering the exposed footbox to the left and right of the shroud and I also covered the brake reservoir while I was at it. It has helped quite a bit more.
Also I see you have the original fans on your rad. I could not keep the car from overheating under 30 mph or so with those so I replaced them with the below (Alan's suggestion) and it completely solved the problem.
MAR-TA11A3001
Radiator Fan, Champion, Plastic, Black, 11.0 in. Diameter, 1,380 cfm, Each
(Mfr. #: TA11A3001)
Cheers,
Craig
