Question about brakes: leading caliper or trailing caliper......
Question is: does a leading caliper have any effect upon rear suspension dynamics v. a trailing caliper? Assume a trailing radius arm type rear suspension.
Thanks in advance.
Bill Kearley
I used to have the goods on this mmmmmmmmmm. That was over 40 years ago. You move me to play catch up on the subject!!! but on the web.
Interesting. I can see it both ways - just a moment around an axle centerline......but also the same vector at different distances from a trailing radius arm pivot point. Hhhhhmmmmm.....still confused.
Bill Kearley
A solid axle, not as much influence. on independent link and upright, things are a bit different. Myself I would never notice. Lets have some more input.
Mine comes from a static analysis of the forces. Whatever force the caliper absorbs is translated into a torque (between the point of pressure of the pad on the rotor) and the axis of rotation (center-line of the wheel). That torque is balanced by the opposite reactions at the upper and lower hub connections. The braking torque is the same (direction and magnitude) whether the caliper is mounted on the front or back.
I just looked in my several books on suspension design, hoping to find a nice quote. None of them even mentioned any preferred location of the caliper.
Terry Oxandale
Skinny Man
I've always placed moment of inertia above any other debatable issues in determining the location of a caliper. Though insignificant, every little bit helps.
I think most cars have been configured for trailing calipers in order to more readily allow the cooling of the discs.
In regard to live axles - General motors seems to also think that torque reaction as well as braking forces react differently dependant upon the side of the car. Noting that many have shock absorbers staggered with one side in a leading configuration and the other side trailing.
While another kettle of fish -
I’ve worked on stock cars (hardly “stock”) which had the rear brake calipers mounted on floaters with links to the chassis. This would load the chassis with a verying degree of weight in each corner and could be tuned.
Ron McCall
Quite a few modern race cars are mounting the caliper in the 6 o'clock position to keep the weight as low as possible.
Ron
Bill Kearley
Another part of this story is, wheel bearing loads are different under breaking when calipers are mounted front vs rear.
