Joel K
Hi,
looking for some recommendations with regard to the following
1)Is it necessary to run a bleeder line from the top of the radiator back to the header tank? Is it sufficient to just bleed the system on setup by opening the top drain valve slightly connect a hose temporarily, bleed the system and close the valve and your all set?
2)If running a line is preferred, what size and type of hose is recommended? Just looking for some standard black rubber hose, nothing fancy.
As always. Thanks for the help.
Joel
Joel
