I switch to a larger alternator from a 55amp race unit due to inadequate power generation. The new alternator is a denso that I had to modify to case to fit. It is meant to be a serpentine belt alternator with a solid mount top and bottom. I run a gilmer/cog belt set up and the alt. is mounted solid at the bottom and adjustable at the top like a Chevy one wire would be. The problem is that the unit vibrates like crazy. I have checked and recheck the alignment. Could it be that the unit needs a stronger top mount? I can do that but I don't want to mask a problem that will put me on the side of the road. The alt worked fine on the bench test and is charging great.
This is the old alt. but the new one is mounted the same way.
